Alpha One, New upper - break in period?
tmh
I just had my Alpha One (gen 1) drive repaired - new aftermarket upper and rebuilt lower (cleaned, new seals, etc.). Is there a break in period for a drive like there is for a new engine? I'll check with the mechanic when i pick up the boat also.
Thanks.
Re: Alpha One, New upper - break in period?
Ayuh,....
I probably wouldn't go out for WOT prop tests,+ acceleration testing for 10 or 20 hours,....
And I would probably Check or maybe change the oil at that time,....
But,...
No Not really.....
tmh
OK, thanks. I'll be changing the oil more often now that I ruined one drive!
As long as it's OK do do some light kids' watersports with a new upper....I don't need WOT for a while!
wca_tim
the aftermarktet drives don't have the gears lapped at the factory... and so need to be worn in to consistent wear patterns... My lowed stopped shedding metal after about 10-15 hours...
