Hi everybody, I have a 1991 Gen 2 Alpha One. I'm attempting to install the anodes on the end of the lift rams, however I'm not having much luck. The kit I purchased says it is for 1991 - present Alpha One Gen 2. It came with 2 anodes, 4 bolts & 4 washers. At the end of my rams are 4 small holes, but none of these holes are threaded and they are slightly a larger diameter then the bolts included with the kit.
What is it that I'm missing to attached these anodes? It's like I need some sort of threaded insert like a small heli-coil or something along those lines. I've been searching online but have not come across anything.
Thanks for any advice.
