I have an Alpha One I/O. I have a sharp knocking sound in the stern drive that changes with engine RPM but is constant whether boat is in neutral or drive/reverse. When sitting idle for more than a few minutes engint temp climbs to the point of pegging out the temp guage. Increasing RPM's caused temp to return to normal.
My first suspect was the water pump in the lower. But it really sounds like the noise is located in the upper. I took off the top cover and observed the drive gear / driven gear while the engine is runnign and they seem to be normal. Ther. The drive gear / driven gear seem to be working together normally. The nut on the end of the universal joint assembly doesn't seem to be knocking onthe drive shaft.
Lastly, when I took off the top cover I noticed there is no ring around the bearing at the top of the drive shaft. According to the diagram there should be a ring and a shim and o-ring but mine has only the bearing. I have never had the cover off before and have had the boat for two years and about 20 trips to the lake? Could the missing ring be allowing the drive shaft to move around and causing something to wear?
Any ideas or suggestions apreciated.
