Re: Alpha One in need of speed
DDBoater, no problem, I figured it was a type-O at first, figuring you forgot the .0 in the middle
Yes I image ole Jake's rear was pretty tight that morning on the river, running that fast. Those (2) Evinrudes have been taken off of that particular boat. The dealer that has it now, is planning to put (2) 125 Evinrudes on it, so I imagine it won't be so fast now. The reason I know this, when I was checking into 3 log Pontoon's I figured if Odyssey's structure was strong enough to handle that speed, it should not have any trouble structually, going 50 MPH every once in a while. My Lextra is heavier and more plush than the Milleninum he was on, and I carry plenty of junk on board, so if I am only able to go between 42 to 45 MPH, that is fast enough, like I have said before, I just want to know I've got it set up right. Still investigating! My 350 Mag, Alpha One Outdrive, running a Power Tech CLU200 PTC3R 17 POLISH ran 41/42 Sunday, it fluctuated RPM's again though and peeked at 5000. <br /> The Service Bulletin on the 350 Mag, put me behind schedule on fine tuning! If I am not Mistaken, Odyssey suggested it should run 44 MPH and I may gain some MPH with a Mirage Plus Prop!<br />We will see! <br /><br />I don't doubt what your saying, but I am begining to fear that the first Used S.S. Mercury S.S. Prop was the one I should have stayed with, and the Moisture under the Dist. was keeping the RPM's down. The guy has sold that prop though now. <br /><br />Here is the link to the Pontoon Speed Record.<br /><br />
www.internetgrapevine.net/partypontoons/index7.html <br /><br /> <br />Performance Millennium Pontoon Boats <br />... Joseph River in Elkhart, Indiana we were certified the WORLD SPEED RECORD at 80.8<br />miles per ... In fact, Pontoon & Deck Boat Magazine has judge Odyssey Boats Best ...<br />
www.internetgrapevine.net/partypontoons/index7.html - 12k - Cached <br /><br />Oh well, I tried! Anyway, Good luck Boatcephus, and DDBoater, I will let you know if the S.S. ever surpasses the Aluminum! I still have a few tricks to try.
