SaintPetter
- Sep 1, 2022
- 3
Hi all,
New to this forum and to fixing my boat, but have been trying to read up here, and want to give it a try.
My 1997 Alpha One Gen 2 has started to grind when I put it in reverse, sounds horrible, and will not engage until I give it a little throttle. I have separate gear and throttle controls, so this becomes a little awkward when docking.
Boat is still on the water, so I was hoping I could get away with just adjusting the anchor stud slightly upwards to give the cable a little more movement as a first step. Is this advisable, or do I need to pull it out and do a full cable adjustment?
Should probably mention that the shift interrupter occasionally will stall the engine when shifting from reverse to neutral as well, but that could of course be separate issue entirely...
Any help and advice is greatly appreciated!
