Alpha One Gimbal Bearing Removal Help
gaanders
I am using the ATD rear axle bearing puller to remove my gimbal bearing in my alpha one gen 1. I cannot seem to arrange this between the bearing and grease seal. Of those who have used this or a similar puller, are you pulling out the grease seal with the bearing? I would like to avoid doing this if at all possible.
Thanks,
Greg
Don S
Re: Alpha One Gimbal Bearing Removal Help
Just use the 3 jaw puller on your slide hammer.
attachment.php
Cptkid570
Ensign
I was able to borrow the slide hammer puller (that Don S posted a photo of) from my local auto parts store, Autozone. They had it as part of their loaner tool program (so you can use it for free)
stonyloam
That is the puller I used, and yeah the seal came out with it. Seal doesn't do a lot anyway so I just put it back in. Not saying that is the best way to do it, just the way I did it.:facepalm:
gaanders
Thanks for replies! I appreciate the help.
Greg
qcarlson
Greg
Find this tool readily avail online and you will have any gimbal bearing out in minutes every time....
Mallory Marine Gimbal bearing remover
mal-9-79820
ktbarrentine
mal-9-79820
Wow...kinda pricey! I'll see if I can "borrow" one!
ponchoman
Is there any way to just tilt the bearing to get it to come our of the slots in the seal? I seem to remember this reference somewhere? Never tried it.
