Alpha one gen2 gear live in water
alldodge
You noticed "oil in the water lube reservoir" is empty and no water in the boat?
The drive has a gear lube reservoir bottle, and don't understand the no water in the boat comment?
AShipShow
A little punctuation could go a long way here.
Sounds like your lube monitor hose is either cracked/broken, or your outdrive seals are leaking. Pull the drive, drain the oil and inspect for water, and do a pressure test. Also inspect the lube monitor hose for damage.
