Scottyboy blue
- Mar 25, 2024
- 3
Good afternoon- My son and l are trying diagnose an Alpha one Gen one Sterndrive problem.?
Boat - 1979 Carver Monterey 27ft - Mercruiser 228 (305) - Alpha one Gen one Drive
Problem: When the Boat is put into gear - either Fwd or Rev there is a violent bang that seems to be coming from the Transom. It is so loud ,that we can't heard if there is any loud clunking.
Maybe the problem lies in the Gears somewhere in the outdrive. Maybe the engine and Drive are not aligned properly. Are the two related.? The gear oil was drained and is clean.
Our plan is to, with boat being on land - check and adjust the lower shift cable -hook up water muffs -warm up the engine - stand behind Drive and shift gears and listen -
We are going to remove both the upper and lower units (impeller change- pressure tests) and with an Alignment tool, check the alignment.
If anyone has experienced this situation we appreciate you comments.
Have great day
Have great day
