I have an alpha one Gen one on a 1983 sting ray with a 170 meecruiser motor. I have no reverse. I have changed all the cables and done the adjustments several times. Also replaced the shift shaft. I still have no reverse even though the gears in the lower unit will engage by hand and reverse will engage by hand at the motor. When I put it into reverse at the shifter I have forwards and neutral. Am I missing something? Just took the boat out and under load will sometimes have reverse. When shifting into forwards the boat will jump before going into gear.
