Alpha One Gen One Monster
MTBoat
For all those friends with much more experience than my one time doing the transom bellows kit etc....bout killed me....I had a few questions for advice.
I had salt water get into the bilge via the ujoint bellows a couple weeks ago and now have take everything out from gimble bearing to all hoses and bellows. I also need to put in a new lower shift cable, which I have no experience with. Everything is apart and I want to start putting together.
1. Do I need to replace or worry about the ujoints? They seem ok, but there was water in there for a short time. Or can I just grease them well and reinstall?
2. Do I really need to order the shift cable tool for taking loose the transom nut, or is a deep socket ok,,,and what's the mm or size?
3. Is there any adhesive I can use besides ordering a tube of the Merc bellows glue....for a likely one time use?
4. Is it easier to do the shift cable first, or start in another order and do it at a given point?
5. I do not have the gimble bearing placement tool...any other socket or tool set up that will drive it home ok?
Thanks for any good guidance, I am hoping to survive this, do a good job, and escape a big mechanic bill, or buying all the special tools right now, I do have some..
Bt Doctur
1 grease the immediately, leaving water in them does them no good
2 a very deep 9/16ths thin wall socket or a donor welded to a 9/16ths socket, or unscrew the plastic guide tube and use a regular socket
3 contact cement or weatherstrip adhesive
4 before ,during or after dosent matter
5 some have used PVC to install them, whatever you do use make sure its on the aluminum tolerance ring and not the bearing race.
Rick Stephens
+1 on dozerII alignment bar comment. And since you need an alignment bar might as well get one that will install the gimbal.
jackd1023
2. My cheap butt welded a nut on a deep well Crapsman oops craftsman socket
Watermann
While your ordering get the quicksilver coupler grease and gimbal bearing grease, even if your gimbal bearing is grease free use it on the U joints and hinge points.
