Kubaat3lover
- Jun 6, 2019
- 443
Hello,
Ive got 2005 Mercruiser 4.3L + Alpha Gen2 drive and this winter I want to drop off my drive for the first time,
when my drive will be off I wanted to:
- replace my Bellows,
-replace Gimbal
-replace UJoints
-reseal drive
+ do the Pressure test of my drive to seal this drive because most probably I have small leak somewhere, oil is in great condition but i have SMALL decrease in the monitor lube after the end of the season. It stops slightly above ADD mark. Also the vent cap is a little wet on top.
S/N on my drive is almost unreadable (check photos) but i think it might me 1A268871 (can You confirm??) and the sticker on the transom says: 0W416383
Anyway, Im not from USA and I will be ordering parts online because where Iam from the parts are quite difficult to reach.
Can You please tell me if that part numbers are okay and what else is reasonable to check/replace
Mercruiser Upper Unit Seal Kit 26-88397A1
Mercury Lower Seal Kit # 26-816575A3
Mercury Marine/Mercruiser New OEM REPAIR KIT-TRANSOM 30-803099T1
Is that correct for my engine?
I found on the forum that Bellows only OEM how about seal kit? Sierra?GLM? or OEM too?
How about the gimbal? Now ive got grease fitting
Thanks
Take care
-replace Gimbal
-replace UJoints
-reseal drive
Thanks
Take care
