Hello.
I'm hoping to get some clarity in replacement seals and procedure. I see that mercruiser has updated the original two seal setup with a single double seal. I plan on getting the 26-88397A-1
upper seal kit. The older two seal setup required a specific tool: 91-817570T. That tool seems like it's being phased out. Perhaps because the double seal doesn't require it?
I'm confused as to what special tool, if any, I need to seat that newer designed double seal into the upper housing at the proper depth. I just finished a full bellows service replacing the 26 year old intact originals. The last thing I want to do is pull the drive, once again, to fix an improperly placed seal. Thanks!
1998 Alpha one gen 2.
