joesuf2000
- Feb 21, 2016
- 2
I purchased an impeller kit and instead of receiving item 47-43026Q06 I received 47-8m0100526. The kit does say it's for an alpha one generation II(s/n OD58748 and above). Also the instructions say it's an update. instead of using the flexible material for the "small hole" gasket it uses a metal gasket. The instructions were limited stated to use the manual as the guide but neither my manual or the kit instructions say to use a gasket sealer such as perfect seal. Note-The "large hole" gasket is made of the traditional flexible material and has a bead of sealant pre-installed. I've read of people having issues with air being sucked into the pump and causing overheating. My first instinct is to pull the lower unit again and put a gasket sealant on the metal gasket but does anyone know for sure that I don't need it(ie small hole gasket perhaps doesn't need it but large hole does)?
thanks
thanks
