ScottieinNC
- Sep 8, 2004
- 54
Hi Everyone,<br /> I want to wish everyone Happy Holidays, and a very Happy New Year for starters.<br />I have a 1997 Bayliner 2252 Ciera Express I/O with the 4.3LX engine. The outdrive is an Alpha One from 2003 (replaced by previous owner)<br />In doing some checks the other day so I can get my winter maintenance list in order, I ran across the bellows that runs in the center of the outdrive. I think it is the exhaust but not sure. I trailer store the boat with the drive tilted fully up and I got a good look at the bellows and seen in between the ribs or corrugations, there is small cracking and what looks like slight separations going on. Not much mind you, but enough I thought I better look into it. I had zero issues with water intrusion into the bilge this year.<br />To make it short I want to go ahead and replace the bellows and whatever else is inside so I can get worry free use out of it, and solve a potential problem before it starts. I use the boat in inland lakes, but have been offshore several mles before.<br /><br />Is this replacement something I can handle myself? With prior Iboats gurus helping before I have freed up the stuck manual steering in an outboard, pulled the L/U off the same outboard engine and replaced all the gears/seals/etc. <br />I would describe my mechanical aptitude as very good and have an extensive collection of tools.<br /><br />Will I need special tools to do this with?<br />Lastly, is there a preservative that can be applied to the new bellows to extend its life any? If the cracks are from ozone exposure, I would think covering the drive when on the trailer would make good sense.<br /><br />Looking for more expert advice from you all......Scott
