Alpha one 3.0 light green gear lube
ScAndal
I drained my gear lube today and the green lube had turned light green. I have read that if it gets milky that water is getting in the drive. Is it normal for it to turn a little bit lighter, or does this mean there is a bit of water entering the drive? <br /><br />Thanks, <br />ScAndal
Re: Alpha one 3.0 light green gear lube
Ayah,<br />Sure Sounds like you're getting Water.......
ScAndal
Is it possible for the water to enter the upper unit rather than the lower unit? The reason I ask is the lower unit is brand new.<br /><br />ScAndal
achris
More fish than mountain goat
The 2 units are inter-connected as far as the oil is concerned. If water gets in one, it'll contaminate both. Was the oil just lighter in colour, but still clear, or was it 'milky'?<br /><br />Chris.............
ScAndal
Its was just a bit lighter green not really milky. I put new gear lube in two days ago though, so it could be slowly taking water.<br /><br />The lower unit is brand new so I'm assuming the upper unit is taking in a bit of water. Is it a major job for a Mercruiser service guy to redo all the seals in the upper unit? Has anyone had this done before? Whats a ballpark time/price estimate?<br /><br />Thanks everyone,<br />ScAndal
Chris1956
ScAndal, The only seals that keep the water out of the uppergearcase are the o-ring on the top end the driveshaft, the small O-ring on the oil passage between upper and lower gearcase, and if your outdrive is a Gen II, the seal on the bell housing for the gearlube resevoir. Why not seperate the gearcases and replace them? If it is a Gen II, you will need to pull the outdrive off the bellhousing and replace the gearlube resevoir seal as well. <br /><br />PS The seals between the upper and lower gearcases are contained in the impeller replacement kit, and the rest of the seals are contained in the outdrive mounting gasket git.
Rhadley
I was quoted something like $500 to reseal both upper and lower. I also saw a post recently in which someone was quoted $550.
achris
Seals in the top box are a breeze to do if you have the tool to remove the bearing pack. If you don't, get a shop to do it.<br /><br />Chris........
ScAndal
Wow you guys have been a great help. I love getting this type of feedback before going to a shop so I don't get screwed.<br /><br />I'll start calling today for quotes on resealing the upper unit.<br /><br />Thanks again,<br />ScAndal
