Took my drives apart - found the impeller face seal about 1/2" from the top of the housing. These pumps have less than 10 hours on them. When I put them in early spring I followed merc manual 14 and pulled up on the vertical shaft while using the tool to press the seal down to the housing.
What would cause the seal to lift like it did??
What are the effects when the seal is that far above the housing?
Thanks
Pete
Thanks
Pete
