Alpha drive will lower but not raise
crazy charlie
Im getting click sound at the trim motor using both trim switch and trailer button to raise drive but the motor is not engaging.Down works as it should.Planning on checking connections at the trim motor.Anything onvious I am missing? Charlie
Nope, not really,.... It's either bad connections, a bad solenoid, or bad trim motor,....
tank1949
BAD CONNECTION! Clean all connectors. Salt water boats are bad about the green stuff.
icyb
Look down the page to test up solenoid and trim motor,I'm going through this on my boat.
  • 6B4R3.PDF
icyb
Wrong one this should be it
  • 6B5R3.PDF
crazy charlie
False alarm....maybe....Battery was weak.Turned the charger on and problem solved.Still gonna go over the connections since it is so straight forward when you are face to face with it.Thanks guys,Charlie
