Alpha 1 wont fully engage
facelift
So here's my story...
I have scoured the forums, but have yet to come across an incident (and more specifically, a resolution) quite like my current dilemma. But I have learned a great deal in the process. Not unlike when I when I broke 5 out of 8 spark plugs on my F150. I assure you I am more intimately familiar with my 5.4 Triton motor than I ever wanted to be. Ha!
I am the second owner of a 1998 Bayliner Capri SS with a Mercruiser 3.0 lx and Alpha 1(gen 2) sterndrive. A very dear friend (RIP) was the first. The boat is a little bit older, but she is immaculate. An absolute sweetheart. Garage kept, never rode hard and put away wet. Always wiped down, cleaned, allowed to dry-out completely, and serviced regularly. The gel-coat, the interior and the motor, at least until now, pristine.
The water levels on Lake Mead where we boat keep breaking record lows. Early in the season, in the dark and in the wind, I mistook a shoal for a channel at the narrow mouth of the cove leaving the marina. The way the wind was blowing the caution buoys made them line-up perfectly, just like runway lights, like they were saying, "come right through here." Unfortunately they were saying the exact opposite and I chewed up the original aluminum prop pretty good. Well, I found what I thought was a good deal for a
Quicksilver SS on ebay. Correct number of teeth, same size and pitch, so I got it. It fit right on, and used the next 3 or 4 outings without incident. I didn't get the significant performance improvement I had hoped for though. Seemed to get on-plane a little quicker and overall maybe a little peppier, but not much. And I did notice about a 200 RPM increase across the powerband all the way through to WOT.
So flashforward to our last outing. It was a perfect day on the water. No wind and we had the place to ourselves, almost no one out there. We set up on a sandy beach, had a picnic, played in the sand, went tubing and adventuring, etc. Then on the way back to the dock it happened. I was cruising about 85% WOT on glassy, silky smooth water, motor trimmed up just a bit and crossed the tiniest little wake from a boat a mile away. Suddenly the RPM's went through the roof. 6k+! I immediately slammed it into neutral, but just as quick as everything else, the engine temp shot up. It was barely idling so I shut it off. That all took place over the span of maybe 10-15 seconds. I sat there for a minute with a sick feeling in my stomach, reassuring the kids and collecting my thoughts. I started it up. It started up fine and sounded normal, but when I put in drive, zero forward motion. Same for reverse. And it was hot so I shut it back off. At this point I'm thinking I've spun a hub. After about ten minutes I try again. This time she is tough to start, running rough when she does, and dies as soon as I attempt to put in drive. I decide that's it, I don't want to make anything worse and we begin the arduous endeavour of getting back to the dock, which is a whole other story unto itself.
So now the situation is: she starts up easily and runs great on the muffs. Cool as a cucumber like always. But as soon as I put in forward, she dies. Same for reverse. With the motor off (obviously), I can spin the prop both directions. In both forward and reverse. In forward, the prop spins counterclockwise but is tight. When I spin it clockwise, it is looser and easier to turn, but there is a rhythmic clunk, relative to how fast I spin it. Presumably, the tooth of a gear or spline not mating with each rotation. The 'clunk' is clearly coming from the vicinity of the leading edge of the bottom of the lower drive section (so just opposite, or ahead of, or in front of the prop). All of that is opposite when in reverse.
I've come here under the assumption most/many of you know far more than I do about this, so please correct me here, where I am wrong about the 'facts' or the assumptions/conclusions I draw from them. But as I understand it, first off, my prop spinning and clunking is backwards. In drive, the prop should spin clockwise and not counterclockwise. This is a righthand rotation prop. And for reference, clockwise is standing behind the boat, looking forward, turning to the right. The boat has the shift assist assembly and roller-type cutout switch. With all the messing around with it, there is no doubt all of that will have to be adjusted properly. But for the immediate problem at hand, I have both, the remote control shift cable (to the helm) and drive shift cable (to the drive) unattached. I can clearly see that the drive shift cable is not bottomed out, but the shift fork that it actuates does not rotate far enough that it is pointing 100% forward. It stops a couple degrees just short. When I spin the prop, I can see the fork bounce with each 'clunk.' If I take some channel locks and put some pressure on the fork and hold it so its points forward, then I can feel the prop lock up against the motor. But that is spinning clockwise. Shouldn't the prop not spin counterclockwise when the shift fork is aligned forward, which is drive in forward gear?
I don't believe the problem is in the linkage because if I hold the shift fork in position and put some force on the prop, it will still 'clunk' on past. It just takes a significant amount of more force to do. Holding fork vs not, that is. I think for whatever reason, that clutch, or dog clutch if you prefer, just will not engage. I think I can rule everything else out, largely in part due to the fact she runs cool on the muffs. That means that impeller is spinning which means she is intact at least to as far as the lower. She runs smooth, no vibration and I can see the coupler spinning. All the cables and cable adjustments are just a means to eventually turn that shift fork, so I've cut out the middleman and gone straight to the supplier on that.
All this means my problem lie in the lower portion of the stern drive. Is that correct? If so, what then is the best course of action? Rebuild? Buy rebuilt? Buy used? I'm a fairly handy guy and got a couple of tools, so unless there's something I should be warned about or some specialized tools required, I think I can tackle tearing into it. I'm just wondering from a cost perspective, what makes most sense?
Oh, and per the prop shop, we can rule out spun hub. And it might be worth note, that I said I 'thought' I got a good deal on prop, because turns out there is quite a bit of cupping and material missing. They probably ground it down to 'pretty it up' for a sucker like me. Explains the nonexistent increase in performance stepping up to stainless. As well as the increase in RPM.
So here is the scenario I kinda see in my head....I'm cruising along at a good clip, motor trimmed up a little on a prop that is probably already ventilating/cavitating a little. When I cross that wake, the prop comes too near the surface and she breaks free. That's my RPM shooting through the roof. But just like throwing a broom stick in the spokes of some body's front bicycle wheel (if that image made you grin, you're evil. you know who you are), somethings gotta give when she comes back down and the water grabs hold of the prop again. And what gave was the inside of the lower portion of my sterndrive. Does that sound about right to anyone else? Sure makes sense in my mind, except for one little nagging bit of evidence.......
.....there was not one speck the size of a grain of sugar sand of metal of any sort whatsoever in that drive oil. ZERO. No colored bands or foam either. Nothing but that pretty quicksilver greenish blue. I THOROUGHLY dredged that oil with a strong magnet. I even drug the magnet slowly on the drive, working towards the drain hole. Nothing. No metal. No water.
I should also mention one of the things I learned in all this research, which I have never done, is that the new oil should be added bottom-up. Pumped in the drain hole. Silly me, I always thought when changing pretty much any fluid, drain from the bottom and fill back up from the top. But if this were a factor, seems it would manifest itself in the form of bits of metal in the drained out oil.
So that's it. That's about the most comprehensive account of the event, the state of the vessel before and after the event, and the specs of the vessel that I can come up with. As well the troubleshooting done thus far. Where do I go from here? I would be quite grateful to hear yall's thoughts & advice.
Kind regards,
JP
Rick Stephens
Sounds like you blew out the coupler at the back of the engine - made of rubber and connects engine to driveshaft at the flywheel. This would also overheat your engine virtually immediately since your impeller is no longer turning. Probably enough friction to spin the shaft on muffs, but not in the water in gear.
Rick
stonyloam
OK your prop will lock when you try to turn it CCW in forward. It works just like your ratchet. Take your ratchet handle and stick an extension on it, point it toward tour face and hold onto the extension. Set the lever so that when you turn the handle CW the extension rotates CW. That is your engine running. Now hold the handle still and try to turn the extension CCW, it locks, turn it CW and it ratchets freely. That is your engine stopped. Your outdrive works the same way. Yeah it can be confusing.
Three possible things, coupler as Rick said or the vertical driveshaft in the gear housing or upper gears. If you can, have someone look behind the engine and watch the splined driveshaft while you turn the prop COUNTERCLOCKWISE with the control in forward. If the driveshaft turns, it is the coupler. If the driveshaft does not turn it is probably the vertical driveshaft or possibly the upper driveshaft gears.
facelift
hello again.
i couldn't decide if i should post to this thread or start a new one. I hope people read/offer input despite how old it is...because the boat is exactly as it was 9/12/15. since then i lost my business, my house, my wife and my mind, but i REFUSED to loose my boat. poor thing spent a lot of this time in the parking lot of a pawn shop, baking in the las vegas heat. but shes back in a garage now where she belongs, and she needs to see the water come spring.
i've had to reread my original post several times trying to piece this all back together in my mind cuz its been so long.
yesterday i figured out if coupler is toast its not the only thing. when i turn prop ccw in forward gear the shaft does NOT turn. i guess i saw it turning with motor running and made a false assumption. but i can turn prop ccw in gear. weird thing is it is not just opposite in reverse. in reverse it spins freely both directions, almost as easy as in nuetral. and the ratcheting (great analogy stony) going cw is more like an uncomfortable clunk.
i know and dread what i gotta do...tear into that drive. i came here cuz i need and will listen to the advice of experience. but as i am looking at the boat, here's a few more observations/thoughts/questions to help yall pin-point said advice:
-if i hold lower shift shaft, prop dont spin ccw. or is WAY, WAY harder to spin
-if i chewed-up or cooked something in there, either from not adding oil bottum-up or if water got in, wouldn't it be evident in oil? water would be easy to see...none. beautiful blue when drained. if it got way hot, it'd smell and look burnt wouldn't it? also, its been my experience with motors in general, when metal like a gear, a shaft or spline go, uh umm, 'out of tolerance' lets just say, its accompanied by an awful, painful sound. and you usually see at least a little metal in the oil
-does the fact it runs fine (on the muffs) in nuetral and dies when i try to go into gear suggest anything?
it all just feels to me like its just not going into gear. the manner in which the cable actuates the shift shaft or what the shift shaft is trying to accomplish. it was running PERFECT that day. no trauma. no horrible sounds. no impact. no burnt rubber smell. not burnt smelling gear oil. just a tiny little wake and then REDLINE.
but what i suspect or think or 'feel' what is going on is worthless compared to what some of yall have seen with your own eyes and know from first hand accounts....so PLEASE, PLEASE and THANK YOU drop some pearls on me! you just cant imagine what i've been through to hang on to this boat. she NEEDS to get wet!
Bt Doctur
Does this mean the drive is off the boat already? If still on the boat FWD has the rod facing in a straight line . If so and the prop is licked CCW, stand on a blade and have someone watch the shaft behind the motor.
Prop moves, shaft moves= suspect the coupler
Prop moves, shaft does not= suspect drive damage
When you severely overheat an engine there is a good chance you melted the shift cable where it passes next to the Y pipe..
This trips the shift interlock switch causing the motor to die.This switch should only move when coming out of gear, IN THE WATER.
If it mves on land shifting, the shift cable is damaged.
facelift
thanks for the reply. answers:
drive is still on the boat. i believe what i am looking at is the "shift shaft." if i crawl under, on the leading edge of the drive, a shaft with a 90 degree bend comes up out of the lower half and mates with a forked shaft from the upper half. when i turn prop ccw, this component giggles. if i hold it in the straight forward position with vice grips the prop is EXPONENTIALLY HARDER to turn ccw. with great effort, i can get it to turn ccw. but no matter what, the shaft going into coupler never turns in conjunction with it.
the temp gauge did immediately sky rocket when this incident occured, but was shut off within literally 10-12 seconds. i hope that wasnt long enough to melt things but i will surely look for signs of that because as i had mentioned, it seems likes its stuck in nuetral. thanks again for reply.
Bt Doctur
OK, first check the oil level by removing the top plug.It should be at the thread level. If not use a blade of grass, coffee stirrer, etc to check for the oil level.
If you can insert it and find no oil ,then suspect it ran low on oil and melted the gears in the upper unit. Remove the 4 bolts in the top cap to visually inspect the gears.Usually a broken drive shaft has the prop turning easily, To be hard to turn it sounds like the upper unit was damaged.
Bt Doctur
Bt Doctur
but did approx 2 Qts drain out? melting a gearset is different than crunching it
facelift
it was so long ago, i've been racking my brain to recall. but the more i think about the more i seem to remember thinking to myself that less than i would have expected drained out. and this would probably be a good time to reiterate that i learned defacto about filling from the bottom up. still dont understand that, but seems its probably relevant. a couple months & a couple of outings prior to this incident, i changed the drive oil. but i did it just like any other oil change. i drained it out the bottom and filled it from the top (which was a pain in the ***).
i'm off next two days (sun/mon) and so i think this will be the weekend....open it up and have a look-see. i will follow your suggestion and start with the top. what is that picture of? i'm assuming damage of the scope its been rendered unoperable will be pretty visually apparent. i'll know it when i lay eyes on the broken link in the chain, wont i?
i've downloaded the service manual pdf. not exactly a light read. any plain english pointers for me before i tear into it? and to be honest, i have the bad habit of being impatient, taking shortcuts, "oh its close enough", reusing gaskets, i'm sure youre getting the picture....anything that ABSOLUTLEY MUST be done according to the book??? i mean, do i really need 38 different kinds of quicksiver lubes & greases? or will some marine grade grease from autozone do ;)
facelift
with anything, i need to be able to wrap my mind it, make sense of it in my head. your point about melting vs crunching is duly noted. and helped me visualize what may have occured. thanks
Ayuh,..... Welcome Aboard,..... In our drives, there's a lower gear case, with it's oil cavity, 'n the upper gear case, with it's oil cavity,...
These 2 oil cavities are connected by a 1/4" oil tube cast into the cases, connected where the cases meet with a quad-ring o-ring,.....
Ya pump the oil in the bottom which pushes the oil up this little tube to the top cavity, without air bein' allowed in, as it's vented out the top as ya fill it,...
Pourin' oil in the top, causes the oil to pressurize the air in the lower cavity, not lettin' the oil in,....
In doin' so, ya end up with not nearly enough oil in the drive, which leads to gears lookin' like the one BD posted,....
facelift
well there it probably is then...the problem & cause.
melted gears caused by inadequate volume of gear oil. nothing "crunched". everything performed as normal. however unbeknownst to me, getting hotter and hotter. until finally melting to the point of no longer being a viable gear. thats when my tach went vertical and my forward motion came to a screaching halt. bummer. i've been looking. them gear sets aint cheap.
i shoud have the definitive answer later today. i hope. if i get a chance to tear into it as i planned. last night ol lady asked if i wanted to "do something" tomorrow. which means do something i dont want to do that she wants to do and forget about what i need to do.
if there's been no word by 0800hrs tomorrow, send SAR to ikea off of I-215. mayday. mayday. mayday. ha!
Rick Stephens
If you have a cooked coupler, then when running the boat in gear in water, with the drag on the prop, will stop the drive from turning. This also stops the water pump and the engine will immediately start to overheat.
In my humble opinion you should pull the top cap off the drive, inspect the gears. Then pull the entire drive (15 minutes at most) and inspect the coupler with a flashlight through the gimbal bearing. If it is melted around the splines you know what you have happening.
facelift
well, yall were all right. had i known how easy the inspection aspect was going to be, i wouldnt have done nearly as much research, and thinking, and thinking about how to explain what i been thinking. i would have just looked. there was no doubt about it. in fact, as soon as i cracked the last of the four bolts to that top cap, i could smell it. i found my metal bits and shavings too! thats why my oil was so pretty...it never been no where near up that high. i believe i'm referring to the drive gear assembly. right under the cap i removed, where the end of the horizontal shaft coming from the motor marries with the end of the vertical shaft to prop. there. whatever you call that ninety degree turn. the two gears that make that turn possible look more like bearing races than gears. theyre almost polished smooth!
so i went ahead and made me a stand today. plan on pulling drive tomorrow and start tearing into it. and Rick, I actually have a coupling. going back to when you originally posted when i started the thread. and i thought i saw shaft spin. i came across a used coupling in great shape for only eighty bucks. i thought if i didnt get it and ended up needing it i'd kick myself. especially after seeing the prices for a new one. and i could very well still be needing it.ill know for sure tomorrow. if not, anyone wanna trade a coupling for a couple gears, lol.
i briefly looked at the manual. doesnt look like replacing gears is gonna be too bad. now that i know exactly whats gotta be done, any pointers on going about it or getting parts???
and generally speaking, when you see this kind of damage is there more to be discovered to be expected?? or is this point the weakest link in the chain?
it made me feel sick when i seen it, but now its starting to feel like a relief knowing whats going on. after all this time, never being able to get to it, but in the back of my mind wondering and worrying about it. feels good to have a game plan. and it feels good knowing i have the help and support of all od yall
thanks to everyone for continuing to help me!
Ayuh,.... Once ya tear it down, 'n clean everything up, yer probably gonna need everything but the shafts, 'n the case,....
By the time ya buy gears, bearin's, 'n seals,...
You've spent enough to buy a brand new 3 year warrantied SEI outdrive,... available right here at iboats,...
Generally speakin',... Gravity carries all those ground up gears right down into the lower's gears, 'n bearin's,...
Look into a complete SEI drive,... Cheaper, Easier, Go Boatin',....
Rick Stephens
I would second that. The special tools can add up quick. And there are a number of them you need. And no warranty at all. I ran an SEI Alpha1 for a couple years. Then sold it to a guy who is still using it when I swapped engines and drives.
Rick
tank1949
With a warranty!!!!!!!!!!! TOOOOOOOOO.
facelift
no question about it, yall been spot on about everything else, and i'm sure this will be no exception, but i gotta tell ya i sure, sure, sure, sure, surely hope this is the one time you've missed by a mile!! i hope your wrong and i just need them two gears. everything else was miraculously spared. and its gonna come apart and go back together without a hitch. its gonna be easy as digging in cool whip. i sure hope. i got a good, positive feeling. HA! ya right. easy as digging in frozen cool whip. things dont go easy for me. ex: pulled drive today. 6 nuts. 5 in 30 seconds. last one took about 3 hours. had a locking nut like on a wheel with locking lug nuts. never had key, never knew one existed. its off & on stand with no (new) damage. i gotta at least open it up and have a look. i completely see your point, and theres no denying the thinking and logic is sound. bummer tho. my little beauty wont be seeing water for some time afterall. that kind of dollars isnt on the horizon. i really and genuinely would like to thank all of you for taking the time to share your knowledge and experience and time and help. especially this forum, but also forums like it are one of the last areas that humanity and civility stills exists, and the inherent goodness in man shows. between trucks, boats, atvs and even appliances i've fixed things i never would have been able to fix alone.
but if you will forgive me.....i think a tear just fell in my beer. i need to mourn.
facelift
No Title
on a different note, anyone ever seen anything like this????? how about you Bondo????
awhile back I opened a can of Bondo-Glass and inside was crazy looking growths! A couple were long, thin crystalline-like structures. Looked just like old-time rock candy. They're "growing" out from the side. And in the bottom was a "blossum" that looked very much like a brocolli florret. Craziest thing ever!!!
The can is about 3-4 years. Well sealed and undamaged. Kept in the garage in Vegas, so temps were 30's to 115+ degrees. I have been googling extensively and cant find a singe mention of anything remotely close to this. Which freaks me out even more. Like an X-Files episode with some new life form....and I've been exposed!!!! Aahhh!!
I assume its got to be like a crystal kind of thing or the way a stalactite grows. Surely it cant be organic like a mold or fungus. I cant conceive of a more hostile enviroment than inside a sealed can of bondo. If anyone knows, I'd love for you to tell me. My curiosity is piqued. If no one responds, I guess I'll call the college....... or the NSA!!!! Ha!!
