Re: Alpha 1 waterpump question
Yes you can do it. However other things should be done. Like greasing the u-joints and outdrive alignment check. Just depends on if the joints have a grease fittings for the joints. It also gives you a chance to look at the bellows from the inside and check for water intrusion of the bellows.
