Alpha 1 u joint replacement
redlinj
Will be in the process of replacing the gimbal bearing on my alpha one. If the u joints will also need to be replaced, can this be accomplished while the shaft is still attached to the out drive? If the shaft assembly does need to be removed, is it just that large retainer bolt that holds it in place? Any special wrench needed???
Chris1956
You should post this in the MerCruiser forum. That is a common repair.
