bowhuntrrl
- Mar 26, 2003
- 320
I've been experiencing some problems with contaminated fuel, so today before I pulled it to the Cape, I decided to put it on a local lake to try it out and make sure all was well after pulling the carb apart and draining the fuel tank.It started up and ran great, but when I stopped to visit some friends, it wouldn't come out of forward gear.This was only after 1 run up the lake and 1 run back, about 1.5 miles total.. The shifter felt very stiff but I could move it in to neutral or reverse position, but it was still in forward gear. I decided to shut it off and mess with it a bit, but when I went to restart, it had no spark. I'm guessing that it's some control issue or possibly the upper shift cable. It figures that when I got it home after being towed in, I checked the spark and it was good. So I put the muffs on and it started right up. I also had all gears functional. Figures !!! Does anyone have an idea what I should look for ???? Thanks.<br /><br />bowhuntr ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
