edthearcher
- Sep 22, 2007
- 116
so i purchase a used sea ray 22 ft pachanga with a alpha 1 out drive. the boat came with 2 props started up the engine really ran smooth, put the engine in gear climbed out to look at the out drive noticed the prop was not spinning true. stopped engine removed prop nut and noticed the sleave running down the center was worn out, got the other prop out, and noticed it also had a sleave in it, you install it by placing a bushing down the center of the prop than insert bushing and prop over the out drive shaft splines, its a 1986 alpha 1 out drive. my question is this common thought the prop had splines not a removeable bushing sorry if this sounds like a stupid question
