Re: Alpha 1 lower unit water pump replacement
Ok folks, I am confused (the wife claims I always am).
Here are the numbers as displayed on my warranty registration card
20140U 06683865 06670846
87173 01/24/84 06674029
I know that the 06683865 is from the engine, and the 06674029 is on the ring on the outside of the transom (I think this is the outdive SN)
Here is what confuses me, the cap on top of the outdrive is smooth about 4x4 with the lift ring recessed. The area around the vent is smooth. All things to lead me to believe it is an alpha 1 however, the gear housing drive shaft has the pre-load pin and I have been told that makes it either an R or MR. arrrrrrrrr
Next, I am replacing the water pump and thought I had all under control, until I started to put the upper housing on and noticed that it has no seal for the shaft (between the insert and the housing) and I am not finding reference to it in several of the online exploded view/parts list, is there not a seal for the upper housing to shaft opening?
HELP!
