Alpha 1 lower impeller housing
1987sylvanoffshore
Drive # a530982 Alpha one 1986
Is there a small opening in the rear of the lower impeller housing (opening up into the exhaust chamber)or is the gasket bad?
Watermann
There's the opening for the driveshaft and water tube. If there's any other openings then the pump wouldn't function properly.
