Alpha 1 Gen 2 Y-Pipe Flapper
saintlouis32
Hey I had a situation that heated my manifold riser and melted the rubber boot.. It also burnt up my flapper, so now im trying to find replacement parts. I can not find the correct flapper. If anyone could please point me in the right directions thanks!
size of flapper
4 1/4 x 2 1/8
Scott06
size of flapper
4 1/4 x 2 1/8
Have a transom housing serial number ? Engine serial number
saintlouis32
Transom: 0D661551
Engine: 0D826958
i bought the flapper in the image i attached. it matched the listed when i searched the serial but that flapper does not fit correctly
Scott06
Transom: 0D661551
Engine: 0D826958
I think im getting the same thing. Looks like the original one piece units were superseded by what you bought. I came up with the part numbers below but i suspect it is what you have.
saintlouis32
yea that is the same one I found.
The Amazn listing said it will fit all 3... A1,A2,A3 but it will not fit the y-pipe i have
2pcs Exhaust Flappers Water Shutters Fits 1982-1996 Mercruiser 807166A3 14348A1 14348A2 Sierra 18-2732​
Ayuh,..... If the collar at the top fits yer oval pipe, it's the right shutter,....
zellerj
Did the new one come with any directions? See if this info helps any, http://www.mercstuff.com/watershutters.htm
Transom: 0D661551
Engine: 0D826958
My flappers did not fit correctly either, so I trimmed some of the rubber so that they fully closed (or at least partially closed) while in the exhaust pipe. Without trimming, they pretty well were stuck open. Poor design in my opinion. Someone said that the castings for the Y pipe were variable, so that fit with the flappers worked with some, not so well with others.
saintlouis32
Thanks FunTimes.. this is the one im am looking for.
So from the looks of it, i have the correct part so let me go try and make it work. I have to be doing something wrong I will let guys know the outcome
Thanks!!
"Please Note, this item has been discontinued by MerCruiser and replaced with our # 66A3 & # 66A2 which are shown below.
This WAS MerCruiser p/n 14348A1 & 14348A2 water shutter. It was used on many V-6 & V-8 applications.
This shutter had a stainless steel plate molded into the rubber. It was 4 1/2 inches long by 2 1/2 inches wide. It is held in place with a 1/8 inch round metal rod which is 3 1/2 inches long and 2 grommets which were included.
The number 14348 is stamped into the stainless steel plate."
saintlouis32
yea the collar definitely didnt fit, im will order a few differents ones and see how that makes out..
Thanks
saintlouis32
I bought all the ones that claimed to be the replace part for the discontinued flapper.. NONE if them fit at all... any suggestions??
