netwizzard
- Jun 5, 2018
- 2
G'day all.
Have '98 Bayliner Capri 185 w/ Mercruiser 4.3L (0L094641) and Alpha 1 Gen 2 (0M470686). I'm in the process of doing my bellows (done! Thanks to all the great info/tricks on iboats), and redoing all the seals in the upper/lower because of drive oil/water seepage/leakage. Of course while I've been at it, I've found things like shift cable (might as well), ujoints (water in drive bellows, might as well), water shutters (completely gone!!), gear oil through hull fitting (broke), etc..
My question here is specifically with regards to the U-Joints. I've looked at the cross-reference in the Adults only section. But they seem to be for inner clip versions. Mine are outer clip (presumably "newer style"??. I say presumably because mercruiserparts.com lists the outer version as NLA??).
So here are the questions:
1) is there a cross-reference for an "auto" version of the outer clip style?
2) if not, are the inner/outer clip versions interchangeable? i.e. will my yokes accept inner clips?
I apologize if this has been answered already. Usually my "google-fu" is pretty awesome, but it seems to be letting me down on this one...
Cheers,
Ben
Cheers,
Ben
