smassey22180
- Apr 15, 2013
- 210
While trying to replace my u-joints, I bent the drive shaft yoke where it enters the outdrive. A new yoke is $100 and when I replace it do I need to re-shim or can I just assume the old and new yoke are identical? My bearings are good and will not be replaced. Seals will most likely be replaced based on inspection upon removal.
This is behind a 95 3.0 LX and several repair places have told me that I may be able heat up the yoke to bend it back. Their logic is the 3.0 does not have enough power to damage the less than perfect yoke. My concern is balance at RPM.
thanks
95 Dynasty 171 bow rider
thanks
