Re: Alpha 1 Gen 1 Correct water pressure ?
After re-reading your original post, I see what the problem is here....I screwed up ! You have a new engine with either the ECM555 or the PCM555 ECM (computer). It is also known as the smartcraft system. The older ECM's did not have a water pressure sensor, just an engine coolant temperature sensor. Soo... this new engine is "looking for" a specific water pressure and will not run right without it. Your options, as I think it was Tommays posted above would be to install a Bravo-type pump on the engine and thru-hull water pick-up to suppliment the water pressure, or possibly to replace the drive with a Alpha-GenII. The other issue, is that the older style analog gauges are now replaced with a couple of digital multi-function gauges that give you a more in-depth view of what the engine is doing. In-a nutshell, you have chosen to install the latest, greatest engine technology in your boat, and it is time to up-grade the rest of your boat to work with it.
