Been reading about ratios, and it sounds like the 5.0/5.7's use a 1.5:1 ratio. I checked my outdrive and it is stamped 1.65:1. will running this ratio with the correct prop to keep the rpm's in the operating range hurt anything over time?
how much does it change the way the motor operates with the 2 different gear ratios?
