My boat was originally equipped with an Alpha 1 gen 2 drive. The drive was damaged and previous owner had a shop swap the only available drive they had which was regular Alpha 1. I was always under the impression the you could not use gen 2 trim cylinders on a regular alpha 1 and vice versa due to length.
Today I pulled the trim cylinders off to rebuild and sure enough they are gen 2 units. I thought the rods were too short to function on a regular alpha 1 drive. I have rebuild kits for an alpha 1 not gen 2 and the pressure relief valve is a lot different.
Has anyone ever seen this before? Could the gen 2 rods have been swapped for regular alpha 1 rods or something? Does anyone have the lengths of the Alpha 1 and gen 2 trim cylinder rod lenghts?
Thanks,
kp
Thanks,
kp
