stormrider
- May 20, 2009
- 17
Hey guys,
I have a 1992 Mariah MX19 with a 4.3/Alpha 1 drive. My first outing last weekend revealed a leak into the bilge that turns out to be the shift cable bellows. From much reading and perusing the informative threads here, I think I can do this myself, rather that shell out the 1,200.00 that local boat service shops are asking. I just want to make sure I will have everything I need to do the job and will attempt a checklist. Please help me add to this or share any other input that you guys may know about
Parts needed:
Bellows kit (all 3 bellows w/ gaskets, water hose, gimble bearing, u-joints, shift cable, etc.)
Water pump impeller kit(want to do this while I have drive off)
Mercruiser Gorilla Snot for bellows
Special tools:
Engine alignment tool
shift cable socket
1/2" allen head socket for hinge pins
Exhaust bellows expander tool
Procedure:
Remove outdrive (6 bolts, place shifter in forward gear before removing)
Remove gimble housing (hinge pins)
replace bellows, shift cable, U-joints if needed (probably will)
adjust shift cable upon reassembly
What am I missing? I think I can do this, with years of mechanical experience plus what Mariah and I have been through in the past (engine replacement). Thanks in advance for your ideas and help!
Parts needed:
Special tools:
shift cable socket
Procedure:
