Discovered that the water hose hose is kinked. Hose was changed early this year and may have finally collapsed a couple of months back. That should explain the sudden hotter exhaust water, engine temp is still good at 150F<br /><br />The kink is behind the bell housing along the arc where it curves upwards to go around the u-joint bellow. Appears that its is too long and kink is worst with drive down, leaves only about a quarter or less.<br /><br />Need advice if the hose needs to be cut to length or used as supplied (its 14 inches long). If needs to be cut, what is the correct length? The old hose was discarded and I can't recall if I compared them.<br /><br />Thanks in advance.<br /><br />Qystan
