JerseyBoater
- Nov 17, 2013
- 80
Hi all,
I'm looking to upgrade the wiring on the boat, and add a gps and vhf for next season.
I already have a dual battery setup, nothing fancy like blue sea, just a off 1, 2, both switch (Which I use as both or off).
The two batteries have the bilge pump float switch and radio memory wire as the only 2 permanent connections. Both are fused and would stay this way.
What I think I would like to do if upgrade the switch panel, and make every electrical item run via the switch. This should allow me to start the boat, and then once out the harbour power up the other devices (stereo, gps etc) if required.
Currently when I turn on the battery switch, the radio starts up, and with the current wiring the new gps and radio would as well.
Are there any problems with this setup apart from the additional wiring? I've seen a few of the stickies where the gps, radio etc isn't switched, but I assume this may just be for convenience?
Thanks
Thanks
