All Around White light Male?
gt6974a
Bought this boat and it doesn't have a 'white' all around light. When and bought one and it was a 3 pin female light.
I noticed the plug the light plugs into is a 3 pinless female connector as well with a fourth pin in the middle pointing out.
Is this normal, if so, how can I find the light? If not do I need a new base?
thx
captain zac
Re: All Around White light Male?
Not real sure if I see what you have or not but I will give it a shoot
The pin that is sticking out horizontally is an alignment pin
There should be a slot in the receiver that it will slide into
Harry
bassman284
I checked my boat and looked around on the net for awhile and it appears the female end on the light and male on the base is the norm. Looks like your best bet is to get a new base. Here's what iboats has:
http://www.iboats.com/Boat-Pole-Lig...0115676--session_id.256502218--view_id.257972
Notice that there are both 2 and 3-pin configurations and different locating and locking systems so you will need to match the base to your light. Might be best to return the light you have if you can and buy the light and base as a set.
gt6974a
yeah, that's what I though, I've been debugging the oil system and now the lighting system has me for a loop, go figure. Here's a pictured of the base:
