Alcohol Stove Fuel
JES233
I was wondering what kind of fuel you like to burn in your stove.I am thinking about trying "HEET"dry gas.Any input would be helpful.Thank you.
SS MAYFLOAT
Re: Alcohol Stove Fuel
Just go to Lowes or Home Depot and get denatured alcohol. I'm not sure about using Heet unless it is 100% alochol. The stuff from the Lowes or Home Depot is the only stuff I have used, Not that expensive either. Quarts or gallons available.............SS
BuzzStPoint
Denatured Alcohol it what you need. It's cheap and it a great cleaner for around the house/shop.
Most companies put it between 98.9 or 99% Then Methanol is added to make it undrinkable.
SS MAYFLOAT
Don't know how your stove is, but mine sometimes will overflow during the intitial lighting. Alcohol fire is hard to see. I always keep a large glass of water to splash on the alcohol just in case. Water will dilute the alcohol and keep it from burning.
rbh
The secret to lighting an alcohol stove is the pre heat!!!
pump it up good, lock pump down, turn on for 2-3 second, shut off, light and let it burn off the fuel.
This pre heats the cup and will allow for better vapourization, just like the really old coleman stoves.
(thinking of switching and going propane myself)
JES233
Thank you for the info.I got some denatured alcohol and it works fine.
My stove is a single burnner type with a tank under burner you fill thru the top.
Thank You again,
John:)
