Alarms
Mlwilkie75
Looking for advice help please. 2003 5.0 MPI mercruiser. Hi have a soft 2 beep alarm right when I hit 1000 RPM all gauges good. Under 1000 RPM no beeps. Beep 2x per minute. Steady alarm above 3000 RP
alldodge
Howdy
Best to use a scanner to check for the issue, but in most cases with your issue is the water pressure sensor on the power steering cooler
And motor serial numbers are best
QBhoy
IAC would be the no1 suspect. Exactly this happened to mine.
Edit. So just read again. Forget the above. Mine didn’t constant beep above 3000rpm. Get it plugged in and see. A constant beep isn’t good. Check your gear oil header tank and all pressures and temperatures too of course
