Hi guys, hope all is well in the boating world for ya! I have a 95' johnson 150hp, that I was running the other day at about 4200 RPM. The overheat alarm went off and it shut down to 2500 RPM and wouldn't go over it. I let it idle for about 5 minutes to cool it down, all the while the alarm still sounding. I had good water flo thru the weep hole on the back of motor the entire time. I pulled the cowl and the heads were not any hotter than normal and there was no burning smell like it had over heated. I idled back to the dock (about 2 miles), put it back up on the lift and flushed it out with fresh water as usaul. My problem now is that the moment I turn the key on the alarm sounds (consant, no break in sound) and it will not go off, also, it still won't shut off! Need help, not sure what is the problem and I really do not want to spend the $$ and take it to the shop and spend the big bucks to have them tell me whats wrong. Thank you in advance for any help that I can get.<br />Thanks<br />Weedy
