alarm?
Hurricane Don
Newbie here! Have a Mag 350 MPI w/Bravo 1. Got a 2 beep alarm every minute. Oil pressure 30-45# , water temp. 165. Had new impeller installed week ago. Dealer said he found most pieces. Does this engine had any sea/raw water pump sensor? If so, where where is the location? Engine serial no. OM350402 with 370 hrs. Alarm sounded after about one hour operation.
NHGuy
Is your drive lube up to level? Alarm sees that too. I don't know for sure about sensor but I have heard of cooling water pressure sensors in MPI motors.
Bt Doctur
water pressure is located in the p/s cooler #17
