alarm sounding after long idle or slow cruise
dakotadodge80
I have a 1996 mariner 50hp. When crabbing and keeping the boat either idling or moving very slowly, the alarm will sound. If I increase the idle or throttle and raise the rpms for 30 seconds, it stops. It has a brand new battery and doesn't happen immediately. Its usualy about an hour after getting on the water. Is it a battery/power issue or overheat issue? Thanks much.
Nathan Bond
That maybe sounds like at low RPM you aren't circulating enough water through the engine, would indicate time to replace the impeller.
