Alarm Question? 130 Evinrude
TxTrukz
I ran yesterday and it ran fine....but the pee hole didn't have a really srong stream of water coming out while at idle. When I got it up to about 4500 rpm it seemed better, but not a really stong streaming flow....<br /><br />Now Today it didn't start peeing at all and Alarm was a steady beep... waited a while and touched lower unit and didn't really feel real hot. Went to re-start and Alarm was going off and it started but still no water through pee hole...No Tell-Tale... What might be my problem before I take it in? <br /><br />Thanks :p
ob
Re: Alarm Question? 130 Evinrude
Hey neighbor.Sounds like you have a waterpump going out.Might just as well install new T/stats as well as having a complete new waterpump kit installed.
TxTrukz
Thanks, for advice neigbor. What do you figure that will run me for that motor. 95' 130 HP Evinrude<br /><br />I am still learning at boating.....<br /><br />thanks again
OBJ
Tx...the lower unit ain't what ya' wanna check. Feel the flat spots on top and just forward of the heads. If ya' can't lay yer fingers there for a few seconds, do what ob advises.....replace the pump impeller and t-stats.
ob
Right at $100 for parts(waterpump kit,and t/stat assys.)$60 per hour for labor and estimated 2 hr.I do all of my own maintenance but my brother-in-law uses Gunderland.Says they treat him real fair.
