basszzilla
- Feb 28, 2003
- 71
I have a 73 evinrude 2 hp #2302 and dont know if it is air or water cooled. Just to be safe all test runs have been in a barrell. I haven't seen any signs of water discharge and there are no obvious water inlet or outlet, just a small hole in the shaft housing just below the motor.I just got this motor running, it was sitting on a shelf in a body shop for thirty years. once I got all of the debris off of it it looked brand new. I removed the tank, cover, recoil starter and carb. I cleaned, reassembeled and replaced gear oil in lower. started on first pull and runs great, although getting the carb reset for high and low speed was a little time consuming. am going to store this little motor in my bass boat in case of emergency, just dont want to burn it up.
