air bubbles for ice prevention
moderator1
Re: air bubbles for ice prevention
crazy charlie <br />Commander <br />Member # 23774 <br /><br /> posted November 15, 2004 12:41 PM <br />--------------------------------------------------------------------------------<br />Since I needed to be on a boat to install my home made bubbler on my piling pole I figured I would do it now since my Mako will be coming home this week.I took a fishtank pump and put it in a clear plastic retangular box a little smaller than a shoe box.I drilled a hole for the power cord and 2 holes for the air lines(there are 2 air outlets on the pump I bought) and screwed the box to the pole.I stapled the lines running down the pole about 2 feet under water.I put a clear piece of plastic over the front of it to keep weather out and ran the power cord along a rope from the pole to the bulkhead.I plugged it in and VIOLA it was bubbling up a storm.I am convinced it will work well.I will obviously wait until the weather is much colder for the results but I will post them .If it works ....not too bad for $14 total.Charlie<br /><br />--------------------<br />crazy charlie<br /><br />--------------------------------------------------------------------------------<br />Posts: 2010 | Registered: May 2003 | IP: Logged | <br /> <br />Robby6950 <br />Chief Petty Officer <br />Member # 42432 <br /><br /> posted November 15, 2004 03:04 PM <br />--------------------------------------------------------------------------------<br />And of course it will be the warmest winter on record and no ice will form and you will never know if it works1 Its a Murphy thing... <br />--------------------------------------------------------------------------------<br />Posts: 452 | From: Puget Sound | Registered: Jun 2004 | IP: Logged | <br /> <br />crazy charlie <br />Commander <br />Member # 23774 <br /><br /> posted November 15, 2004 03:23 PM <br />--------------------------------------------------------------------------------<br />You are probably right and I hope you are!!!Hmmmmm Maybe I should go out and get a new snow blower??? Charlie<br /><br />--------------------<br />crazy charlie<br /><br />--------------------------------------------------------------------------------<br />Posts: 2010 | Registered: May 2003 | IP: Logged | <br /> <br />mattttt25 <br /><br />Lieutenant <br />Member # 16962 <br /><br /> posted November 15, 2004 05:01 PM <br />--------------------------------------------------------------------------------<br />and as soon as that mako is winterized, you'll have a week long heat wave. reason why my boat doesn't come out until late december. if i don't need to break ice to get it out, it's too early... <br />--------------------------------------------------------------------------------<br />Posts: 1429 | From: Annapolis, MD | Registered: Sep 2002 | IP: Logged |
crazy charlie
Bring on the heat wave!!!!!!!!!! A winterized 150 ocean pro would be UNWINTERIZED real fast.Charlie
llfish
By an aerator for back yard fish pond and use it to keep the water moving!
Mark42
Would those pipe wrap electric wires work on the pilings? Just wrap it around and plug it in. I think they only draw a few watts and should keep the ice from forming.<br /><br />If shorting out is an issue, the wire could be put inside a 1/2 or 3/4" plastic hose, sealed at the end, of course. <br /><br />Mark.
crazy charlie
With my luck ,I would either short out the whole marina or burn it down .Charlie
cuzner
Hey Charlie something I saw a few years back.. an old sump pump hooked up to a timer( he had 2 set up)ran them 5 min per hour. It was an inexpensive system to hook up.Don't know about hydro usage though.<br /><br /> Jim
