Re: aftermarket pwr tilt/trim
Aussia,<br />Here are what I believe are your options. First, and probably what you have looked at it the CMC tilt/trim, which is about $700. Second, if your real lucky you'll grab that one on e-bay, and hopefully it will work. Third, check out the panther
http://www.panthermarineproducts.com/products.html the model 55 sould be enough for your engine. There on sale at
http://www.sportsmansguide.com/ I think for about $420. I don't personally own one yet, however there's one on it's way. I think these are all of your options, I only know because I have a 72 johnson/evinrude 50hp. Good luck with what ever you decide. Ross<br /><br /><br />Keep the prop wet and the engine dry.
