After running the outdrive on sandbar engine smokes in back smells like rubber.
BudL1te
I hit a sandbar at about 1500 to 2000 rpm. Motor bogged down and stopped.
I could smell Rubber.
On the back of the engine where the drive shaft is connected I can feel sticky rubber.
It is a 71 Mercruiser 4 cyl
Rear motor mounts solid.
One front one loose.
I believe I need to replace the coupler but have no Idea where to start or what I will need (special tools)
Any help would be apreciated.
Buddy
Failproof
Re: After running the outdrive on sandbar engine smokes in back smells like rubber.
Pull the engine. Pull flywheel cover. Order new coupler. Reasemble. Align engine using new mounts if needed.
Welcome to Iboats..... :)
I'll be the 1st to send my condolences..... your gonna have to pull your engine.
Burnt rubber smell and sticky rubber back near the shaft is almost a 100% fried coupler. The coupler is bolted behind the engine's flywheel and the shaft from the outdrive slides into the splines in the coupler.
Yours is most likely toast.
haulnazz15
Time to inspect the coupler, as you have likely spun yours. As was mentioned, you have to pull the engine and flywheel cover. Not a terribly difficult repair, but definitely a pain the butt.
BudL1te
Thank you for the responses.
Will I need any special tools to do this? Alignment tool?
Where is the best place to get a coupler?
Oshkosh1
Ensign
Once you pull the engine, it's pretty straightforward.
Alignment tool?
Yes, you'll need to align the motor again...so an allignment tool is necessary.
Depends on whether you want a brand new one(online/dealer) or used(e-bay). Quite a few used out there. Just helped a friend with one a couple of weeks ago. He purchased a good used one for $85...cleaned it up and went on with no issues.
92rslt1
I just did the same thing!
It was easy to pull the motor and replace it. If you have worked on cars, then this is cake.
4 hour job on my 454. Used a tree since my puller was too low. Good for a laugh, but it works.
Min was expensive, but the best price I got was from ebasicpower
haulnazz15
I'd hesitate to get a used coupler unless you don't mind possibly replacing it again. There's little you can inspect other than splines to tell if a coupler is in good condition. I'd eat the $200 or so and get a new one from ebasicpower or here at iboats. The ONLY reason I reused the coupler on my new engine was because I new its condition and treatment over the past 20 years.
