Scandia_Eagle
- Jul 17, 2012
- 8
This problem involves a 2004 35 HP Evinrude, 3 cylinder 2-stroke. From a cold start it runs fine, good power, strong water flow out the telltale, no limits on duration - I've tested it for 15 - 20- min at WOT and it shows no run-time problems. After shut down, it will start again and run with no problems for the first couple of minutes. After a 5 - 6 minute wait, however (long enough to go get trailer and put it in the water), the engine will fire and run in short bursts, but will not sustain operation. If it sits for 20 minutes or so, faster with the hood off, it will start and run just fine again. Have tried 3 different tanks of gas from different sources to no effect. I noted that the carburetor bowls feel quite warm (maybe even hot) to the touch - am I having some kind of vapor lock problem due to heat soaking after shut down? Other explanations for what is going on? Thoughts most appreciated.
