After market replacement serpentine belt 4.3GL-J part no reqd
Lynall
I am after a back up get me home belt just in case I need one, but cannot seem to find any cross reference for the volvo penta part number
It a 2009 4.3 GL-J motor
The oe part number was 3889126 superceded by 21132390, oe in the UK is over 60 gbp!
I realise a copy probably wont have the fancy grooves/notches but as its just a hopefully never to be used spare Im not to fussed
I would remove it and get it measured, but raw water pump has to come off.
skinnydip
Re: After market replacement serpentine belt 4.3GL-J part no reqd
Had similar experience here in US and found out the OE belt was slightly cheaper than the Gates brand. I therefore went with the OE and when I opened the box I found it was made in Mexico. Wish I would have gone with Gates now. I forgot how I cross referenced. Will let you know if it comes to me.
Also, something I found out 40 miles offshore is that the water pump has to come off for belt replacement. Not a big deal except my motor has a bracket that stabilized the water pump and it takes a long extension to get to it and I did not have one. As soon as I got home I got 2 belts and put one on the motor and one behind the bracket and zip tied it out of the way so that I can put on my spare with no tools needed. Just something to think about.
Lynall
Thanks for the reply, if you remember how you cross referenced it please let me know, Ive spent ages looking on the net come up empty handed, I think the idea of cable tying belt in place is a good idea.
If no joy i will have to remove pump and see if I can source one from a bearing factors.
