Re: aerator & recirculater - no power
Confused by the number of lights you are talking about. Are you saying you have two indicators. One that shows the aerator/recirculator is on and there is also an indicator in the switch that turns them on and off? Weird and redundant. So if the ON/OFF switch is powered, there is obviously power at least up to the switch. So your diagnostics starts by checking for voltage at the OUTPUT (load) side of the switch with the switch ON. No power = bad switch. 12V present = switch is good so move on to the next item in line which apparently is the second light. Then the light and the pumps are in parallel so power splits either at the switch or somewhere along the line. If the light has no power IN and the pump doesn't have power IN then check for in-line fuses. If none, then check the ground on the light and the pump. Since both are out, bad grounds would be unlikely but I can't see your boat so who knows what that wiring looks like. The point is to follow +12 volts from the switch. when you lose it you found the problem.
