Re: Aerator Pump Replacement
Start from the outside intake hole on transom. Remove the filter/screen by turning counterclockwise, you should see a loc nut that you will loosen, and then you should be able to remove the aerator pump.Mine was platered in with silicone, which you will want to do when reinstalling.
