I have two aerator pumps on my boat. When I hit the switch on the dash both fuses blow at the same time almost immediatly. I pulled both pump cartridges to make sure there is no junk in them. Both are clean. Could the switch be going out?
Chances are the switch is NOT the problem since it rarely is. Disconnect both pumps and then flip the switch. If the fuses still blow, the wiring is the issue. Is there a timer (adjustable or fixed) in this system? If so the timer may be bad. If the fuses do not blow, connect on pump and retry. If the fuses now blow the pump is bad. Try the other one.
