2007 Maxum 1800MX bowrider, 2000lbs, Mercruiser Alpha 1 3.0L 135hp I/O. Current prop is I believe the factory prop 832832A45P21, 14 1/2 X 21, 3 blade.
I'm trying to decide if it's worth the investment to swap out props and just how much difference it will make. As well, the cost involved. The main reason I would switch props is to improve the hole shot.
The boat is used for overall recreation, abit of exploring but also to pull tubes (2 singles), waterskiers, wakeboarders. Mostly my immediate family uses it. 2 young kids @ 7 & 10 and I'm 185lbs. The boat will get me up on skies or wakeboard fairly easily. I notice the difference with my 200lb friend. He still gets up, not as easily though. Wasn't able to get up my 220lb brother on skis or wakeboard. Not sure how much of his lack of technique was involved. I can't see it being a huge factor on skis (2), he was fighting the boat on the wakeboard though.
How much of a significant difference should I expect by going to a 19 pitch? And a 4 blade prop will also improve the hole shot over a 3 blade? And the only downside is a loss of 2-3 mph on top end speed? (which isn't a concern to me, I usually run 4000-4200 rpm at approx 33-35mph).
I also don't quite understand the significance of prop and WOT. I found on this link http://www.marineengine.com/parts/prop/wot_prop.html that my WOT RPM's should be 4400-4800. For how long is it safe to run at these rpm's and what is a good rmp to run at for cruising for say 5-15+ minutes?
If I go down to a 19 pitch prop, my rpm's will increase approximately 300-400? Is this correct? Does this really make a difference if I'm not running full speed? I typically run at the numbers mentioned above for 2 reasons: 1) fuel economy and 2) it seems fast enough.
Thanks in advance for any advise.
